Prosti tek - AR 156 1.8 TS 16V
OdgovorNapisal/-a veloce » Po Mar 06, 2017 9:55 am
Zanima me nekaj. Po čiščenju lopute, se mi je prosti tek na avtu dvignil na cca 1500 obratov in noče pasti. kaj bi to lahko bilo? Motorček prostega teka ali kaj drugega? Motor sicer deluje BP.
Vozilo: Alfa Romeo 156 1.8 16v TS Sport Pack 02
Prispevkov: 5516
Re: Prosti tek 156
OdgovorNapisal/-a alfa_samec » Po Mar 06, 2017 10:23 am
Poskusi ECU reset. Procedura:
1. Disconnect the negative lead from the battery for a minimum of 45 minutes. Some people recommend overnight but that is not really necessary.
2. Reconnect the battery negative lead
3. Put key in ignition, turn to MAR and leave for 90 secs
4. Turn off the ignition, but not remove the key and leave for 90 secs
5. Start the engine but do not touch the throttle and let the car idle for 15 mins otherwise the car will not rev freely afterwards (as V6 owners know at their peril)
6. Turn the car off and leave for 10 mins
7. Start the car and take her for a blast
Note:
normal text = ECU Reset
and italic and underlined = Throttle reset
Prispevkov: 11683
Re: Prosti tek - AR 156 1.8 TS 16V
OdgovorNapisal/-a veloce » To Mar 07, 2017 6:30 am
Pa je to dejansko učinkovito? Je že kdo sprobal pa je delovalo?
Prispevkov: 5516
OdgovorNapisal/-a alfa_samec » To Mar 07, 2017 7:12 am
Ja.
Prispevkov: 11683
Vrni se na 156, 147, GT
