Variator faze in solenoid TS
OdgovorNapisal/-a kosir1234 » So Nov 10, 2012 2:43 pm
bolš k selenia 20k, sam če ga ne dobiš res ugodno bi raje dal notr motul-a xcess 8100
kosir1234
Prispevkov: 3687
OdgovorNapisal/-a alfa_samec » So Nov 10, 2012 2:44 pm
Ti je tisti solenoid puščal olje?
Edit: agip 2000 ni nič posebnega, je drag za to kar je. Imaš boljše in bolj poceni alternative od Mobila do Totala pa Motul itd. pa 5w40.
Zadnjič spremenil alfa_samec, dne So Nov 10, 2012 2:45 pm, skupaj popravljeno 1 krat.
Prispevkov: 11590
OdgovorNapisal/-a El Barto » So Nov 10, 2012 2:44 pm
Ja točno to je problem, olje teče mimo in ne skozi variator (kakor je pri Nord motorjih).
Problem olja na min je to, da se precej bolj greje, s samim variatorjem pa še vseeno nima veze.
Nord variator:
Novejši TS:
Še tole paše zraven:
Closed Phase
When the closed phase is required (idling and full power area), the electromagnet (1) is de-energized, thus the valve distributor (2) pushed by the counter spring (3), stays up preventing the passage of the oil leading from groove (A) from reaching the variator. In this case the timing of the intake valves remains unchanged (closed).
Open Phase
If the open phase is required (average speeds at high torque), the electromagnet (1) is energized, thus pushing the valve distributor (2) downwards. In this position the oil, leading from groove (A) enters chamber (B) of the piston, from where it passes through a special hole intro groove (C) machined inside the latler.
The oil can only leave this groove through the upper hole (in communication with the oil delivery duck (C) to the variator) as the lower hole no longer leads to the exhaust duct (E) because the valve distributor (2) is lowered. The oil passes through duct (D) and (F) and reaches the chamber (G) moving piston (4) axially towards the engine. The outside piston (4) is fitted with helical teeth and as a result of the above-mentioned axial movement it is force to move clockwise (as seen from the timing side). The rotation is transmitted through a straight-toothed grooved profile to the pinion (5) which is screwed onto the threaded lug of the camshaft (6) and transmits rotation to the shafts. This way the timing of the intake valves are changed by 25º.
When the electromagnet is de-energized, the valve distributor (2) returns to its initial position, shutting off the flow of pressurized oil to the piston (4), but allowing the oil to return to the exhaust due to the thrust of the counter spring (7).
Arese V6 Power
Made in Italy, perfected in my garage
Alfa Romeo 166 2.0 TS 2000
Alfa Romeo 147 1.6 TS 2001
Prispevkov: 6428
OdgovorNapisal/-a alfa_samec » So Nov 10, 2012 2:49 pm
Pripisati je še potrebno, da je puščajoč solenoid problem zato, ker več ne steče celotna količina olja do variatorja.
Prispevkov: 11590
OdgovorNapisal/-a Mboy » So Nov 10, 2012 3:51 pm
Selenoid nič ne pušča, tako da je videti v redu.
Mboy
Prispevkov: 112
Pridružen: Sr Avg 25, 2010 10:04 pm
OdgovorNapisal/-a Mboy » So Nov 10, 2012 4:04 pm
Takole pa motor lavfa:
http://www.youtube.com/watch?v=q8TUQQk7jeM
Zaenkrat še vredu... Malo hrešči (snemano z Galaxy S2)
Mboy
Prispevkov: 112
OdgovorNapisal/-a kosir1234 » So Nov 10, 2012 4:16 pm
Ni mi všeč tale zvok...
kosir1234
Prispevkov: 3687
OdgovorNapisal/-a El Barto » So Nov 10, 2012 6:29 pm
Mislim da je mišljeno pod "spušča" notranji izpustni del, ki posledično ne aktivira variatorja.
Arese V6 Power
Prispevkov: 6428
OdgovorNapisal/-a alfa_samec » Ne Nov 11, 2012 6:23 pm
Evo še moj solenoid, pa si poglejte razlike.
Lepo se vidi kako curlja olje iz njega vse okoli po motorju.
To kar je notri, ni olje, ampak so usedline in umazanija ostankov olja, ki je precej gosta, kot katran.
Takole:
Gosta zadeva, ki blokira pretok olja in se nabira v solenoidu.
Pa še dokaz, da niso vsi solenoidi enaki - eni imajo dihtunge, drugi ne, samo široko plastiko.
Zdaj sem ga sestavil nazaj skupaj, če bo pa puščal, ga bom pa zadihtal s silikonom po robu. Moj GTV ima isti solenoid, ki isto pušča olje, ampak ga je nemogoče odvit, brez da bi vzel dol pokrov ventilov, pa potrebuješ novo dihtungo. Pri plastičnih TS-jih gre pa brez problema.
Prispevkov: 11590
OdgovorNapisal/-a Scremer » Po Nov 12, 2012 12:15 am
In kje potem pride tista vzmet, ki se jo zamenja?
Scremer
Vozilo: AR159
Prispevkov: 1665
Pridružen: To Apr 05, 2005 8:43 pm
Kraj: Kransterdam
OdgovorNapisal/-a kosir1234 » Po Nov 12, 2012 1:05 am
Ja na odmični gredi v variatorju...
kosir1234
Prispevkov: 3687
OdgovorNapisal/-a alfa_samec » Po Nov 12, 2012 9:27 am
Tule:
Prispevkov: 11590
OdgovorNapisal/-a Scremer » Po Nov 12, 2012 12:02 pm
Potem je vse kar se dela na tem selenoidu, to da se spuca in po potrebi zadihta s silikonom? Se lahko uporablja kakšno namensko čistilo za zračne lopute?
Scremer
Vozilo: AR159
Prispevkov: 1665
Kraj: Kransterdam
OdgovorNapisal/-a alfa_samec » Po Nov 12, 2012 1:11 pm
Niti slučajno, ker pride v olje! Očistiš samo s krpo. Pa pri dihtanju moraš pazit, da ne zabašeš kanala za olje s silikonom. Velja pravilo manj je več.
Prispevkov: 11590
OdgovorNapisal/-a El Barto » Po Nov 12, 2012 3:07 pm
http://forum.alfa156.net/forum/forum_po ... ?TID=37191
PLASTIC ??????????
No ja verjetno so mislili, da bo plastika lahko laufala brez olja ...
Aja pa stična površina/navoj se ne paca s silikoni in podobnim sranjem, za ta namen je pač tesnilno oz. lepilo za navoje.
Itak je pa ravna stična površina, ki omogoča kovinsko tesnenje.
Arese V6 Power
Prispevkov: 6428
PrejšnjaNaslednja
Vrni se na Vodniki
