mare87
Prispevkov: 927 Pridružen: Pe Jul 24, 2009 8:37 pm
Vozilo: Alfa Romeo Giulietta
Kraj: Škocjan
Po Nov 15, 2010 8:52 am
Dräger napisal/-a: Dovolj da je čistilo potegnilo po zračnem vodu.
To je samo moje razmišljanje in ne trditev.
Če rabiš drug LMM -> 031/873-151
imaš mogoče LMM za prodat? ti javim, ker danes ne bo nč, ker ima servis vse polno in grem ju3 pop.
Ziga.
Prispevkov: 629 Pridružen: Sr Okt 06, 2010 12:42 pm
Kraj: Celje
Po Nov 15, 2010 10:39 am
1.6 16v TS 105km, ima luftmesser kok jaz vem in ne maf-a ?
italiano è il migliore <3
Po Nov 15, 2010 10:53 am
MAF=mass air flow sensor - angleško
LMM - Luft masse messer - nemško
Oboje je pa senzor pretoka zraka po slovensko.
Ziga.
Kraj: Celje
Po Nov 15, 2010 10:59 am
Aha. Brez zamere, nisem vedel. hvala za obrazložitev
Po Nov 15, 2010 11:15 am
Skor sem že vzel meter iz predala in začel merit
mare87
Kraj: Škocjan
To Nov 16, 2010 2:31 pm
včeraj, ko sm šel na šiht in vžgal alfo je lučka za motor ugasnila
To Nov 16, 2010 2:46 pm
No evo. To je gorela lučka zato, ker je bil LMM odklopljen in je takoj vžgal napako.
mare87
Kraj: Škocjan
Ne Dec 05, 2010 11:02 am
lučka za motor se je zopet prižgala. tokrat sm si nabavu obd kabel in program fiatecuscan. izpisal mi je naslednjo napako:
Anomaly of the catalyzer functioning being detected in the signal emitted by the two lambda probes that are installed upstream and downstream of the catalyzer itself (with some equipments only);
check with exhaust gas analyzer and oscilloscope gases and signals of both probes before carrying out any replacements.
The reason for this fault is that ECU has received very high signal from the sensor. The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was activated for this fault.
kaj naj zdaj? avto normalno gre. ko lučko za motor ugasnem, se prižge po približno 60km...
Prispevkov: 6837 Pridružen: Ne Jan 15, 2006 7:25 am
Vozilo: Alfa Romeo Stelvio Q4 2.0 MA 280 2019 Alfa Romeo 166 2.5 V6 2001 Alfa Romeo GT 2.0 JTS 2006
Ne Dec 05, 2010 1:04 pm
Koda napake?
Čeprav je precej verjetno MAF problematičen.
mare87
Kraj: Škocjan
Ne Dec 05, 2010 2:39 pm
koda napake je: P0420 catalystic conventer, signal visok, kritično
katalizator?!
Ne Dec 05, 2010 2:58 pm
mare87 napisal/-a: koda napake je: P0420 catalystic conventer, signal visok, kritično
katalizator?!
Ali lambda sonda.
mare87
Kraj: Škocjan
Ne Dec 05, 2010 3:01 pm
jutr bom šel na amzs preverit pline...
preostane še kaj drugega?
Ne Dec 05, 2010 3:05 pm
Hm ne vem, mogoče pregled izpuha od motorja do druge lambde, če kje kaj spušča, ter prevert konektorje in kablovje obeh lambd.
mare87
Kraj: Škocjan
Ne Dec 05, 2010 3:11 pm
v fiat ecu scan mi kaže podatek samo za 1 sondo, neko vrednost. za drugo sondo pa nč ne piše, kot da je ni in graf nč ne pokaže za 2 sondo, med tem, ko se za prvo premiko gor in dol
Ne Dec 05, 2010 3:36 pm
Kakšen motor pa imaš: Euro 2 (CF2) ali Euro 3 (CF3)?
Tukaj si pa poglej, kako to ugotoviš:
viewtopic.php?t=17670
Po forumu brskajo: 0 registriranih uporabnikov in 37 gostov
