The Monroe ReflexTM is a new shock absorber that helps to increase the stability of the car and keep it on a safe trajectory, especially in emergency situations. This is the result of the Twin Disc technology, a unique concept that makes the new Monroe ReflexTM valve react faster to the smallest motions of the suspension, before conventional valves start to work.
Pomojem se pa ne zgreši ne s Kayabo in ne s Sachs/Boge-jem, saj sta obe firmi priznani, sploh Sachs/Boge (ZF group) in tudi dražji od Monroe-ja.Twin Disc technology is based on a special valve that has an extra tuning stage for very limited piston oscillation. This extra tuning provides maximum damping at very low piston speed, which is the piston speed associated with the most dangerous driving situations – such as sudden lane changing and emergency braking – thus controlling any motion of the vehicle. The two disc stacks incorporated in the new Monroe ReflexTM shock absorbers let varying amounts of fluid through the valve, depending on the driving situation, thus allowing a tailored response to each driving circumstance and need.
Jaz mam pa 195 po števcu pa vrjetn še kašnga zravn in se tud obnaša avto ko da je gumijast!svicar napisal/-a:moja ima 130k...sploh zadaj je katastrofa.Ko zaviram na ravnem imam občutek kot da zadnji konec vleče na eno stran...pa sm tudi sprednji niso več nevemkaj, zato sem reku da bom menjal...nevem...eni grozno hvalijo Bilstein...zato sem vprašal če ima kdo kašne dobre izkušnje...Ne rabim nekih športnih da bom vsako luknjo čutil, amapak ene navadne za lagodno vožjo pa za solidno ceno.
+1ARfan napisal/-a:Jaz imam Eibach pro-system in sem zelo zadovoljen
