prodaja to A.Triglav?Aluminum Engine Guard
for all Alfa 156 (also GTA)
This stunning laser cut, salt resistant engine guards offers superior protection compared to OEM trays.
The added free hight of up to 22mm at the rear section and up to 40mm at the front section, means no more scraping over speed bumps.
A must with lowered suspension!
Easy installation using original bolts and mounting points.
Compatible with lower front brace installations (4mm spacer required at the two rear mounting points)
http://shop.alfisti.net/Tuning-Styling/" onclick="window.open(this.href);return false; ... :2910.html
majo samo plastično zaščito?
(nazadnje ko sem plužil sneg, mi je malo počila ta plastična zaščita+ en visok robnik je poskrbel da sem to polomil
