Če prav zastopim, samo datoteko fw.bin kopiraš na prazno SD kartico (brez mape), pri ugasnjenem radiu vstaviš SD kartico. Nato pa ne smeš izvleči kartice toliko časa dokler ledica utripa, ko pa neha je stvar posodobljena.Bearex napisal/-a:Prepisano iz saita:
Update instructions
Copy "fw.bin" file into the root directory.
Insert the SD Card any time.
If the Head Unit is switched off the update process will start.
Don't remove the card, while the indicator LED is toggling!
Kako bo pa to rešeno - programsko?, na ICSju imaš izbiro cd samo od 1-6. Za prikaz teksta pa bi bil pomoje potreben poseg v ICS, ali nerbnet napisal/-a:Ja zadeva deluje SUPER!! Komaj čakam ker bo kmalu suport za 10cd-jev in še menda text bo izpisal izvajalca!Tako obljubljajo na saitu!!![]()
Unfortunately the ICS of the 166 & 147 (937high sure...the others I don't know at this moment but I think not...) doesn't support CD text.(
The latest firmware support playlist control...
And contain some smaller bugfix.
Iz kje pa si to kopiral? Prosim za link.Bearex napisal/-a:Unfortunately the ICS of the 166 & 147 (937high sure...the others I don't know at this moment but I think not...) doesn't support CD text.(
Ga bom vprašal tudi za playlisto.147/156 - 10cds
166 - 6cds
(at this moment loudlink explorer is in beta phase....later you can see only
6cd case of 166)
Using:
You can drag files into cd1...cd6 (cd10) windows, and can select the
playling order using drag and drop.
After you've finished the ordering (or changing source CD/DVD/etc of the
mp3s ) click write SD card.
And the contents of the 6 / 10 windows is copiing into SD card in the given
order.
Skratka uporabljajte Loudlink explorer!Loudlink explorer create _dirinfo.txt in all directories.
It contain the order of the playing. (Order: What you gave preveiously in the Llink explorer using draging the files in the windows)
You don't need copying or anything. Just use Loudlink explorer, and order the songs in the cd1...cd x windows.
