Tempomat AR 166
RSTDRIVER
Prispevkov: 8
Pridružen: Pe Dec 14, 2007 12:29 pm
sem novopečen lastnik AR166 brez navodil za uporabo in me zanima, kako naj bi se pravilno vklopil tempomat? (ma kokr sm bukov mi ga ne uspe in se mi poraja vprašanje, če sploh dela?)
Alfaspider
Prispevkov: 2664
Daš obroček na ON, nato se pelješ hitreje kot cca. 30km/h in obrneš obroček za nastavljanje hitrosti naprej ali nazaj in to je to. Včasih zna štekati kakšno stikalo na pedalih sklopke ali zavore in zato noče vklopiti tempomata.
RSTDRIVER
Prispevkov: 8
Alfaspider napisal/-a:Daš obroček na ON, nato se pelješ hitreje kot cca. 30km/h in obrneš obroček za nastavljanje hitrosti naprej ali nazaj in to je to. Včasih zna štekati kakšno stikalo na pedalih sklopke ali zavore in zato noče vklopiti tempomata.
Hvala!
(sm wedu de nisem tok bukow :roll:)
grem pogledat stikala....
Prispevkov: 7132
To activate the cruise control:
turn the ring nut switch to the ON position
set the desired speed (> 30 kph)
turn the SET ring nut towards the (+) or (-) sign
release the accelerator pedal.
The cruise control can operate in the entire permissible engine range for versions with either manual or automatic transmission.
The cruise control does not operate:
in 1st gear or reverse where there is a manual gearbox
in P, N or R where there is automatic transmission
below 30 kph.
The action of turning the ring nut switch to the OFF position cancels any speed previously set.
A warning light in the control panel, activated by the injection control unit, indicates whether the system is operating or not.
For safety reasons, the A.S.R. (Anti-Slip Regulation) function has priority over the cruise control.
When the operation of the A.S.R. is over,, the cruise control function is automatically reactivated at the speed set.
Manual disengagement of cruise control
The driver can disable the cruise control by:
the turning the switch to the OFF position
switching off the engine
operating the brake or clutch pedal (the last speed is memorized and can be recalled by pressing the RECALL button)
operating the automatic gear selector lever in position P, N, R (the last speed is memorized and can be recalled by pressing the RECALL button)
vehicle speed below 30 kph (the last butterfly angle remains memorized and the speed can be recalled by pressing the RECALL button)
operating the accelerator pedal
In this case, the cruise control remains on, but the management of the accelerator pedal is allowed.
Automatic disengagement of the cruise control
The system automatically switches off the cruise control if there is:
acceleration due to a steep descent
deceleration due to a steep incline
operation of the gear selector lever without using the clutch.
The system automatically switches the cruise control off in the following failure conditions:
sensor signal failure which implies the desire of the driver to alter the driving conditions:
accelerator pedal potentiometer
clutch switch
brake switch
brake lights switch
cruise control RECALL button
cruise control SET ring nut
failure with the other system sensors or components:
injection/ignition control unit
engine rpm sensor
vehicle speed
automatic transmission selector lever position (where fitted)
a failure in the control system or the components which lead to an engine malfunction:
turbocharger sensors/actuators (where fitted)
motorized butterfly casing
air flow meter
engine ignition
injectors
Iz eLearna (pa se mi niti pod razno neda prevajat).
BRLE
Prispevkov: 625
El Barto a ročke si kupil na AC? Koliko je pa za čakat?
Prispevkov: 7132
Jaz imam tam že poseben status - pokličem in imajo (ali pa naročijo) ... 8) :lol:
Nevem kako je sedaj, baje je bila moja zadnja.
Pokliči in izvedel boš. :wink:
BRLE
Prispevkov: 625
El barto - a nisi obljubljal ene foto reportaže vgradnje tempomata - po moje bi blo fajn videt kako in kaj si počel.
Prispevkov: 7132
A v galeriji ni OK.
No čene je tu link v Galerijo - KLIK
Aja še to - po vgradnji, ko prvič daš kontakt ni nič drugače, le če vklopiš tempomat zasveti lučka. Pri naslednjem štartu pa tudi pri začetnem preverjanju (ko zasvetijo vse lučke) zasveti tudi za tempomat.
BRLE
Prispevkov: 625
Ups oprosti sem mislil da boš kar tukaj lepil slikce - nisem bil pozoren - super reportaža - marsikdo se lahko kaj nauči od tebe (tudi jaz :? ) Sedaj pa ko se mal vreme popravi in najde čas veselo na delo - =D> !
Prispevkov: 7132
Še slikovno gradivo naknadne vgradnje tempomata:
najprej se odvije 3 vijake (imbus) na zadnji strani volana (v prečkah), da se lahko odmakne airbag.
airbag se odmakne in stakne konektor iz ohišja airbaga - navaden šraufciger zelo pomaga 8) (hvala Foggy & wolf66)
odvije se 5 vijakov (imbus), ki držijo pokrova okoli volana skupaj (en vijak je pod pokrovom varovalk). Potem se z lahkoto sname zgornji pokrov, na spodnjem je pa potrebo staknit konektor za airbag
temu sledi demontaža volana - najprej matica
nakar pa še izdelava in uporaba snemalnika (stranski luknji imata navoj M8, razmak med njima pa je 70mm) - multifunkcijski :lol:
ko je volan odstranjen, se odvije dva vijaka (en pade neznano kam :? ), ki držita ročke in odklopi konektorjre
namesti se nov komplet ročic (bel konektor na vrhu je za tempomat), še prej najdeš izgubljeni vijak :)
pred ponovno montažo volana sem še namazal gibljive plastične dele, da bodo gladki kot dojenčkova ritka :) (Becutan krema )
Tako, skopirani iz galerije. :)
fiatseba
Prispevkov: 482
Pridružen: To Jan 10, 2006 3:42 pm
Kraj: ljubljana
kaj pomeni gumb RCL na tempomatu? Čemu služi?
Apophis
Prispevkov: 313
Pridružen: So Jan 02, 2010 12:45 am
Kraj: Gorenjska
fiatseba napisal/-a:kaj pomeni gumb RCL na tempomatu? Čemu služi?
RCL=recall
S pritiskom na to tipko nastaviš tempomat na prej izbrano hitrost.
Npr.: vklopiš tempomat in nastaviš na 130Kmh potem moraš zavirati in se tempomat izklopi, potem pa samo pritisneš RCL in avto sam pospeši nazaj na prej izbranih 130Kmh.
Upam da nisem preveč dolgovezu. :mrgreen:
jtd-M 20V
Prispevkov: 4995
Da se temopat spet nastavi na prej nastavljeno hitrost. Se pravi če si prej vozil 160 s tempomatom, in si bil primoran bremzat, potem ko je AC spet prosta pritisneš RCL in avto spet pospeši nazaj do 160.
EDIT: Eh so me prehiteli :).
BRLE
Prispevkov: 625
Sej voziš 160, oni pred tabo pa samo 130 - ga boš že ujel... :D :D :D
fiatseba
Prispevkov: 482
Kraj: ljubljana
pr men so za volanom torksi 27
ah žal nimam te sreče in original priklopa ni :cry:
a je že kdo naknadno vezal to sploh in pa kako se da popravit uno ročko za žmigavce če se jo da, v levo ne vrača
