This thing is awsome. The fellow building it says he decided to use an Alfa motor because he didn't want the expense of a custom Harley type motor and all the chrome. That was not the reason I was expecting but it does make sense. Alfa 2.5s are cheap, you can buy a decent one for $300 and it can be overhauled for about $1000. For someone willing to do a lot of custom work it could cost less then a traditional custom bike. The Alfa V6 fits inside the dimensions of the stock Harley frame! This fellow is using a four speed transmission (a Harley transmission?) and a KICK START!
Check out the intake system. The suction of those pipes under full throttle is probably tremendous. I guess you can't wear a tie while riding this bike.
