Honda Accord 2,2 i Ctdi 140 ks
a33
Prispevkov: 583
Pridružen: Če Jul 07, 2005 2:12 pm
Kraj: MB
kdo ve kako se obnese ta motor in kako tunning, poraba, napake?
GORA
Prispevkov: 741
Kolega ima karavana s tem motorjem in 340000 km in nobenih bistvenih problemov do sedaj.Je pa kupil novo in se precej vozi relacijsko.
Novejšim letnikom so zaribavali motorji zaradi bizarne napake ECUja.
Due to an inappropriate software setting of the Engine Control Unit, the oil level in the engine may increase due to fuel dilution during the Diesel Particulate Filter (DPF) regeneration. If the oil level increases too much it may prevent the engine from decelerating as intended, the engine may continue to run even if the ignition is switched off. This may result in engine failure. The driver will not have any warning of this failure.
2008-2011 Accord Diesel, 8500 komadov.
LaŠko-TeaM
Prispevkov: 1771
ahah a japonci tud znajo grešit :lol: pa vsi tolk hvalijo tele je**** hondde :puke:
Cefizelj
Prispevkov: 49
Pridružen: Po Sep 13, 2010 6:23 pm
Dizelski motorji so za njih itak bolj eksotika, povsod po svetu prodajajo bencinarje, v Evropi pa dizle pol je pa takle... :)
